Songbirds
Apr 01, 2018Explorer
dougrainer wrote:
I don't know where you found that manual. BUT, your system is HWH and there is NO reset procedure and NO Level set procedure AT the touch Pad. These are the 3 links for every model HWH level set procedure. Doug
https://www.hwhcorp.com/mi9543.pdf
https://www.hwhcorp.com/ml47508.pdf
https://www.hwhcorp.com/ml47509.pdf
You are correct about the HWH system shown in PHOTO and as to finding the information in a manual NO, that did not happen. But I looked and made some calls. My Finger is pointing at the Button to press to reset them. This was a 2005 Model Winnebago Tour. As to your statement "
dougrainer wrote:There was on this system and I may have called Winnebago. Thank you for your feedback and will correct above and look forward to more expert input about the Automatic Self Jack Leveling System. Now I'm wondering if you mean RESET is not shown on the Touchpad you are correct as well. But when my auto jacks would not level back correctly, I searched for an answer until I found someone in the know. In my calling different people who should be in the know, I found someone who informed about this RESET Procedure and wanted to SHARE with my fellow RV'ers in this forum and others who may have the same or like, an issue I had. Thanks Again for your sharp keen input and ideas to help make this appear better online in this RV Forum.
