dougrainer
Apr 01, 2018Nomad
Songbirds wrote:
If anyone has used this post to correctly reset AUTO leveling JACKS or have used this to the same reset I would sure enjoy hearing from Y'all Thanks In-advance.
OK, is the button on the SIDE of the touch pad or are you pointing at the LEVEL button? WHAT do you think a reset button will do for an HWH system? Regardless of what you may have found, UNLESS you talked to HWH, there is NO RESET button or procedure on a HWH System. Period. FYI, I have over 30 years and still working on HWH systems with HWH factory training. The question remains, WHAT malfunction did you have that you thought a reset would fix? There is NO WAY PERIOD that you can adjust the level sensor from the Touch Pad. Doug
From HWH. "That maybe a way to reset someone else's leveling but not HWH. On the HWH leveling you should dump the air and use the jacks and a bubble level to level the coach manually and on that coach there is a control box right behind the right front tire and you will need to adjust the level sensor using the page I have attached to this email to reset the level sensor".
BTW, CHASSIS maker does not matter on a Leveling system. The chassis maker does NOT install the leveling system the Coach Maker does.
