lucytravel12's avatar
lucytravel12
How to Winterize w/ air compressor
The water pump on my '87 Falcon is broken so I can't pump in the pink stuff. I'm shopping for a new camper so don't want to make any repairs. Any tips on how to winterize the pipes with an air compressor?
  • Purchase (or go to Home Depot and get the parts to make your own) adapter for city water connection to your air compressor hose.
    Adjust compressor regulator to ~45psi.
    Drain and bypass water heater. If no bypass, then drain and install plug/anode.
    Hook up compressor to adapter on trailer.
    Work your way through the trailer, starting at your guess of the farthest away shower/faucet/sink/toilet/sprayer and run till no more water comes out.
    Open low point drains and blow till no water.
    Remove compressor, open all faucets.
    Remove water heater drain/anode (if you didn't have a bypass) to drain newly acquired volume of water.
