- boogie_4wheelExplorerPurchase (or go to Home Depot and get the parts to make your own) adapter for city water connection to your air compressor hose.
Adjust compressor regulator to ~45psi.
Drain and bypass water heater. If no bypass, then drain and install plug/anode.
Hook up compressor to adapter on trailer.
Work your way through the trailer, starting at your guess of the farthest away shower/faucet/sink/toilet/sprayer and run till no more water comes out.
Open low point drains and blow till no water.
Remove compressor, open all faucets.
Remove water heater drain/anode (if you didn't have a bypass) to drain newly acquired volume of water.
38,769 PostsLatest Activity: Apr 24, 2002
