K Charles wrote:
OP here. I checked the resistance in the coil and it is bad. I am just looking for a place to buy the coil alone. HWH sells the coil and stem in one piece and is very pricey. There are many types where I use to work but not one for this stem.
I recently had a fuse blow and burn up the inline fuse housing at the pump. Quite accidentally I saw a flash at the motor terminal when current applied. The terminal was extermly hot, and more importantly loose and corroded. This caused heat, which caused resistance and blew the fuse. Cleaned to terminal at the motor, replaced the fuse with circuit breaker and solved the problem.
