Tom_Barb's avatar
Tom_Barb
HWH 610 Leveling system.
Our Jacks will deplete the air when the system is activated, then quit.
ignition is on, Acc.,, brake set, ground is nearly level.
you push the ( ON/Auto ) the control panel will light, and the red light will illuminate, the air will dissipate. ( go to 0)
then the pump will not Start as usual. you can hear the solenoids click as usual. but no pump noise or pumping action.
key pad shows a yellow light on the pad.
  • Your manaul reference is operators manual. One I posted is troubleshooting.
    Top center appears to be excessive slope is that correct?
  • enblethen wrote:
    Which yellow light comes on?
    top center
    enblethen wrote:
    this is correct manual. Manual
    Nope.. mine is MI.1126/MP05.5001/CHD-S
    09APR99
  • enblethen wrote:
    Check to insure large cable to pump has power to it.
    Should have a solenoid on it.
    Done,, no change.
  • Check to insure large cable to pump has power to it.
