willr's avatar
willr
HWH air suspension leaks
I have a 2002 Monaco Windsor 40' PBD, ISC 350, with air leveling option. After I park and level, within 24 hours, the rear of the coach appears to have lost its air. Any suggestions on where to begin looking for causes? I am currently near Kamloops BC - any recommendations regarding a reputable RV repair facility? Thanks for any help.
  • Thanks for the suggestions everyone - I will begin the process of identifying the issue tomorrow and let you know the outcome.
  • On another forum, this was discussed and the writer did all the work himself. Turned out to be the air valves but with a specific problem. He replaced the O-rings in the valves but it didn't fix the problem. He then dismantled an air valve and discovered it had an o-ring UNDER the electrical solenoid. Since it was old and cracked he replaced it and that turned out to be his problem. Seeing as your coach is an older one (and mine too) it looks like that's where I would look. I'm hoping to last just a little longer.
    Good luck and safe travels!
  • John S. wrote:
    Sounds like the rear six pack.
    X2. For your wallets sake, I hope that it is something different. I just replaced our six pack of valves.
  • Bucars RV 262109 Range Road 10 Balzac, Alberta, T0M 0E0 Phone:(403) 207-1666 or (800) 267-8348 Email: service@bucarsrv.com (7 hours from you) or check on:
    http://www.hwhcorp.com/dealers34.html#CAN
    Ride height valve or airbag is a guess.
