Jim@HiTek wrote:
enblethen wrote:
Look through these for the jacks.
HWH manual list
I did. None of them match.
dougrainer wrote:
The Bunny is a Travel indicator you push to put the suspension in travel mode. This is a Winne ONLY system. When it is lit you are safe to go. When you search HWH's website, sometimes you MUST search the OEM specific part. Doug
http://www.hwhcorp.com/ml19516.pdf
http://www.hwhcorp.com/operators43.html
YES! Doug, I owe you a prize. The 2nd link has nothing I can use, but the first link is my system. Not the same ML number, but it's got everything I'm looking for on my system, including the handles on the hydraulic valves.
Thanks!
But...to reiterate my earlier question...when I push the bunny, what's supposed to happen? Will it be obvious?
BTW, The booklet I have doesn't say anything about any bunny related 'light'. So, I don't know what this means, "When it is lit you are safe to go.". When what is lit?
Sorry, it does not light up. The 2nd link shows ALL the Winne HWH operator manuals. I was not sure which specific system you had. There are a few 310 manuals on that 2nd link. All the manual says is push the Bunny and the RV will get to travel height. I guess that means it makes sure the Air Bag solenoids are closed and the Air suspension raises to travel height. Since I rarely work on Winne/Itasca, that Bunny is a Winne ONLY touchpad. Doug
"The suspension will stay in the dump mode until the park
brake is released or the "TRAVEL" button is pushed, if the
ignition is in the "ON" or "ACC" position".
In this case the Bunny is the Travel button.
