dougrainer wrote:
The switch is just a ON/OFF rocker switch nothing else. It just passes thru 12 volt positive power. IF you have a short, then the switch is too long and the terminals are touching ground or you have not reinstalled the plate cover correctly and something is grounding out. Doug
This is the HWH P/N RP90315
The switch is slightly longer, so I will check to see if it is grounding to one of the joy sticks underneath the plate. This looked like a simple replacement, but had me baffled when the fuses started to blow. Thanks Doug and Pete for clarifying this for me.
