dougrainer
Feb 01, 2014Nomad
1. There is a solenoid for EACH jack even on the 725 system. IF there is no external fluid leakage, and a jack retracts, then THAT solenoid is defective. YES, I have had 2 solenoids fail on a new system before. What the OP needs to do is simple. Extend all 4 jacks and take EACH solenoid manual release spring lever and open it to allow each jack to retract a few inches. this will allow any debris in the solenoid to possibly be flushed out. IF that does NOT work, each jack solenoid that continues to leak back will need replaced. LOW fluid will NOT be a concern on a HWH system.
2. Thundermountain--- IF no external leakage the Jack solenoid for THAT jack needs replaced. But, on your solenoid, do the same thing as above. YOU have to release the solenoid with a 1/4 inch nut driver. Open and close the offending jack solenoid to flush the solenoid. IF that does not work replace the solenoid. Doug
38,782 PostsLatest Activity: Sep 18, 2026
