aintnothin's avatar
aintnothin
hwh leveling sytem
OK my 2001 ultrasport, my leveler unit power light comes on, 1 yellow light for the side that needs to be leveled comes on, but when using the leveler handle, some times it works but alot times it don't. Any one know where to the relays and pump is located?
  • Found the problem. The fuse holder was defective, worked if you put pressure on it. Will replace in the morning.
  • Johno02 wrote:
    Look up under the front right corner, in front of the wheel well.
    It's not there. I took the control panel apart and cleaned the connections but when I put it back together there was a spark when I turned it on. Now the lights on the panel don't come on and can't figure out how to replace the fuse on the panel.
  • Look up under the front right corner, in front of the wheel well.
