Ka_RonExplorerJun 14, 2014Hydraulic fluidWe have a 1998 Fleetwood Southwind with a super slide and there is a reservoir under the slide that had fluid in it. Over time the fluid has slowly disappear from the reservoir. No idea where it...Show More
Old-BiscuitExplorer IIIJun 14, 2014Typically......ATF (tranny fluid) but you need to check manualHydraulic fluid doesn't evaporate.......so if level is going down you have a leak.At a fitting, piston seal, reservoir gasket, someplace. And reservoir should only have fluid added/topped off when slide is retracted (in).
Related ContentQuestion on Hydraulic FluidProper Hydraulic Fluid to use?Hydraulic Fluid for HWH LevelersHydraulic fluid for Lippert Ground Controlhydraulic fluid
