Ka_Ron
Jun 14, 2014Explorer
Hydraulic fluid
We have a 1998 Fleetwood Southwind with a super slide and there is a reservoir under the slide that had fluid in it. Over time the fluid has slowly disappear from the reservoir. No idea where it...
Old-Biscuit wrote:
Typically......ATF (tranny fluid) but you need to check manual
Hydraulic fluid doesn't evaporate.......so if level is going down you have a leak.
At a fitting, piston seal, reservoir gasket, someplace.
And reservoir should only have fluid added/topped off when slide is retracted (in).
