dougrainer
Feb 07, 2016Nomad
You should have HWH jacks. Go to the TOP of the offending jack and you will see a 2 wire quick connect. That is the DOWN light magnetic switch. DISCONNECT that switch and the light will go off. You can also Start the engine, put the system is STORE, take 6 or 8 foot 2x4 as a lever and you can lever the offending jack fully up. Since you have a 2008 model, the problem is defective inner jack seals and that jack will need rebuilt or replaced. Doug
