dougrainer
Feb 21, 2016Nomad
rv4jimnme wrote:siggyd777 wrote:
Hydraulic levelers are being pulled up by the springs , but the engine must be OFF and you must be in ACC to have the valves open for
the hydraulic fluid to return to the tank when you press Store.
Siggy
So you cannot have the engine running or the hydraulic fluid remains in the lines? Also we still cannot locate the reservoir, apparently one would have to stand on their head? Winnebago said it would be on right side in front does that mean facing the coach or not? I mean is right side the drivers side or the passenger side?. Thanks
He is wrong about his statement. You can have the Engine running at anytime you are operating HWH jacks, whether extending or retracting. To find the reservoir. have someone operate the jacks(extend) and walk around the RV until you locate the noise of the HWH pump. Right side or left side is stated when sitting in the drivers seat/ Right side will be the Pass side. Doug
