- Branson_N_TucsoExplorer III have a 2004 Providence, mine is located on Passenger side of motor home, in the Baggage bin.
The 3rd. One from rear. - John_WayneExplorer IIWhen you find make sure what oil it takes most are trans fluid NOT hyd. oil.
- wildtoadExplorer IITry the front wheel well. My 2000 Hurricane on a Workhorse chassis hat it there.
- AikenRacerExplorerSometimes these things are behind outside panels with no opening handle. I had one a while back on a Thor that I had to remove two bolts on the bottom of the panel to open the panel door. From the exterior, it appears to be a dummy panel. Don't understand why the manufacturers don't put openers on all exterior panels.
- wa8yxmExplorer IIIEasiest way may be to do a walk around while a partner operates the jack controls assuming the pump runs.. Follow your ears.
Option 2 is follow your hose.. I'd start with the front jacks. follow the hose from one of the jacks. you MIGHT get lucky. If it runs into who knows where try the rear jacks. - MrWizardModeratorDid you Look under the living room slide out
On many RVs one system is used for both slides and jacks
My 97 Bounder the jack pump is curbside up front of the wheel
On the previous RV it was curbside rear - LwiddisNomad IIIOwner's manual is of no help?
See https://www.fleetwoodrv.com/for-owners/support/owners-manuals
