Cheryl_B's avatar
Cheryl_B
In RV park. Now have car to drive. Disconnect RV battery?
I've been driving my motorhome for all errands but now have a car to drive for the next 2 or more months. The rv battery is going to go dead just sitting here.
Do I have to start the engine every few days to keep this from happening, and let it idle for 5 minutes or so, or do I buy one of those trickle charge battery keeper things? I see them for about $30 but not sure if that's what I should do.
And how does that work anyway? What recharges the trickle charger?? Oy.
  • RoyB's avatar
    RoyB
    Explorer II
    I would think it would be better to trickle charge your truck start battery while sitting for long periods.
    This would be a great application for one of those smaller wattage solar panels (AMAZON). Even on cloudy days and in the shade you should get an amp or so into the start battery during high Sun each day.
    But since you will have shore power power available to you 24/7 the far best gaurenteed solution is to just plug-in a low output trickle charger... Something in the 12V-2AMP rating... Have to watch the 12V receptacles on most of the vhicles now that don't stay HOT with the ignition key OFF. Be sure to find one that stays ON all the the time if you get one of the trickle chargers that have the 12V plug on them.
    My OFF-ROAD JEEP used to sit for weeks alot and one of those solar panels that lays just inside the windshield area on the dash was the perfect solution for me to keep the Jeep start battery going strong. I just plugged the solar panel into a always HOT 12V plug on the Jeep dash.
    Batteries love to have a float charge going all the time... One caution I would think is not have more than 13.2VDC feeding the float mode to keep the possibility of boiling out fluids down to nothing...
    Also disconnecting the NEGATIVE battery terminal on the truck start battery is something I am not in favor of doing on my trucks here while sitting. Too many electronic things are still running to keep the truck computers set correctly. They always say they will reset themselves after being disconnected but I would not chance that. This is just me - but having to go the dealership to have them reset your computers at a minimum of $90-$100 cost for a five minute job on their computer just seems out of line haha...
    Just some tid-bits from me here...
    Roy Ken
  • bukhrn's avatar
    bukhrn
    Explorer III
    1. Are you camping with hookups, (electric) ?
    If so, you don't have to do anything, the converter that charges your house batteries, should also be charging your chassis battery, (at least mine does).
  • Plug the battery tender into the 15 amp outlet on the pedestal or an external one on the coach. It will keep the coach battery(s) up without overcharging.
