gemert
Jul 17, 2014Explorer
Kirk wrote:
If you were connecting to cable there is no power there only an rf signal so there should be no spark. If it works intermittently you probably have a bad connection. Have you tried putting new ends on your cable or replacing it?
Not knowing how the system is actually hooked up I wonder? Could the TV amplifier be shorting out against the shield ground on the TV cable or maybe the center conductor? And could it be intermittent because the amp is not always on? Just wondering!
38,707 PostsLatest Activity: Feb 20, 2025
