- IvylogExplorer IIIMaking it move to the current Class A posts.
- IvylogExplorer IIIHad to replace my POWERMAX PM3-100 12 VOLT DC 100 AMP charger with very few hours on it.
- IvylogExplorer IIIMerry Christmas Yall!
- IvylogExplorer IIIDelete
- IvylogExplorer IIIDelete.
- IvylogExplorer III:S Only took me a month to realize I had all the information to figure the duty cycle of this refer as I posted this above:
"This EnergyStar Whirpool 21 CuFt Refer has a energy guide of $44/year and 410,000 kWh/year or 1,123 W/day or 94 Amps/day... So out of my 500 AH battery bank I should be able to go two days before getting to 50% and needing to recharge. $44/year is 12 cents a day... It's amazing how energy efficient they have gotten these things."
1,123W/day divided by 100W running equals 11.2 hours/day or a 47% duty cycle. - IvylogExplorer IIII've added a 120V outlet from my 1000W inverter next to the V/amp meter in the bedroom so I can power the DVR Sat receiver and TV 24/7. This will stop the 10 minute powering up of the Sat receiver and will let it record favorite programs while boondocking. When out of the coach I turn off the main converter/inverter to save on it's 2amp standby draw.
Last week I saw that HomeD has a newer model:# WRT311FZDB which is the same size for $800. - IvylogExplorer IIIIn another post there was a question about how to charge the refer batteries while traveling. I ran a cable with a 200 amp switch on it from the house batteries to the refer's battery bank. By turning it on the alternator will be providing the 8 amps of power necessary to run the refrigerator. After Boondocking and before getting on the road I run my generator to charge the batteries up instead of using the alternator. Having it put out 100+ amps for several hours cannot be very good on it even though I carry a spare alternator.
- IvylogExplorer IIIIt depends on where your condensing coils are located. If they are on the back then yes you need the roof vent to let the hot air out or 2" at the top. On this refrigerator the coils are at the bottom and I have decided to leave the outside vent open in the summertime to let the 90° air out. I'll probably close it in the winter so the heat stays inside. The refer blocks the roof vent opening so it is only 1 inch deep by 30 inches wide and I'll probably leave it open that small amount.
- JimExplorerInteresting.
I'm curious what your refer users guide says about airflow around the new refer. I was looking for a residential two years ago for a friend and all the models I looked at required 2" open space above the refer for the most efficiency. And then some open space in the back, and underneath, but zero clearance on the sides.
But it looks like the OP has 0" clearance on the top? Does it vent out the original roof venting?
38,763 PostsLatest Activity: Dec 13, 2025
