supercub
May 22, 2015Explorer
If you're worried about the bolts coming loose, even though you use Loctite. You can drill the bolt heads and safety wire them. Another thing you can do to see if the bolts are turning (loosening) put a line on the head and continue it to the surface the bolt head is up against. That way if it turns the mark won't be lined up. You can use a felt pen or a little line of paint. Loctite should be sufficient though.
38,782 PostsLatest Activity: Sep 01, 2026
