marbilupton's avatar
marbilupton
Intellitec Line Monitor
I am plugged into a 30 amp outlet and I noticed my Intellitec line monitor was flashing "37 amps" and the only thing turned on was the living room a/c. I turned the a/c off and it was still flashing the same thing! Anyone have an idea where the problem could be and where I should be checking? Thanks
  • No fix yet. Have it in the shop. Waiting for the tech to call Intellitec to get some troubleshooting advice.
  • To reset my internal EMS I have to shut off the main power. Then shut down each individual item in the RV. Turn on the main again and start turning on each unit. Most likely you just pulled too many amps and EMS shut down everything like it is supposed to do.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    It is saying "I am confused" do as Shadow said, only disconnect ALL power 12 volt and shore/generator.. Wait a few minutes,, re-connect.
  • Reboot it by unplugging and disconnecting batteries. See if that helps.
  • How about your converter? I have a Victron battery monitor that tells me how much is going into or coming out of the battery. Ultimately a VOM is your friend and tell you how much and where current is going to or coming from, a clamp meter makes it very easy.
