Canadian_Rainbi's avatar
Oct 27, 2015
Intermittent Cruise Control SOLVED
Solved. See my latest post.
2002 Itsaca Horizon, Cumming 5.9, Allison 6 speed (M2000?? WAG)
Cruise control drops out intermittently. Few seconds, minutes, or many minutes. Sometimes runs fine for hours. It seems to be most stable on well paved smooth roads. However, hitting a rough patch can't be pointed to as the cause. That a bump won't set it off, but it happens much more frequently on rough roads.
I have tried fiddling with the control lever, can't make it act up.
It is often a problem after start up then settles down.
When we had the Silveleaf working we could see the CC speed being reset downwards.
Sometimes, driving at a steady speed with cruise control off, I take my foot off the throttle to find that it (CC) had engaged at that speed.
As a junior Radio-TV tech in the 60's, I can tell you I HATE intermittent problems! And I know how long it can take to track them down. At $100.0 per hour shop rates I've been putting this off for several years.
Anyone else run into this problem?
