Gjac's avatar
Gjac
Explorer III
Jun 12, 2015
Intermittent front end banging on the left side
I left on a trip this morning with my wife and grandson going out to Yellowstone national park, somewhere in New Jersey I noticed a clunking sound almost like it was coming from the steer safe on the left-hand driver-side. I stopped and noticed the LH spring was about 1/16 away from the lower A arm. The RH side had a 1/2 in clearance. After several rest stops and spraying the springs and noticing a loose bolt a on the upper RH shock mount which I tightened, the noise was still there, so I started looking at the steer safe again. Next rest stop I noticed a square bolt with a stop nut that looked like it backed off 1/4 in. As I tightened it,it would pivoted the spring away from the Arm. Called steer safe and they verified that was the right thing to do. Drove about ten miles or so with no noise an all of a sudden it was back again. No vibration in the steering wheel just had the MH aligned 2 years ago and front end parts replaced. Anyone have any thoughts about this problem?
