Farmboy666 wrote:
Executive wrote:
Gardnerna wrote:
(snip)
Also this is a new shower valve and control. The old one we replaced also jd the same problem. We hoped by having a brand new shower faucet it would fix our problem. (snip)
I'm assuming you've simply replaced the shower wand end and not the pressure balance valve which would be behind the shower wall. If so, then your problem won't go away until you replace that valve...Dennis
Thanks, FarmBoy..I read that. However, to replace the control valve means getting behind the wall which is not something everyone can and/or will do. Hence, my assumption. Looking for clarification from the OP....safe travels...Dennis
