Gene_M's avatar
Gene_M
Inverter usage while underway
Greetings to all. This may or may not be a tough question.
I am presently considering the purchase of an inverter to keep my reefer running while underway. I have a single 12v deep cycle battery. Charging of the battery occurs as follows:
1. Through an IOTA ILC3055 with an IQ4 on the attached DLS55 converter while on shore power,
2. While the 4kW generator is running,
3. While the vehicle engine is running via the alternator and battery isolator.
I would like to hook it up by plugging the 30a shore power cord into a suitable receptacle with a relay that will disconnect the converter when the inverter is in use(details were found here http://www.doityourselfrv.com/rv-inverter-install-diy/ (method 4).
My battery has 850 CCA with 170 minutes of Reserve Capacity, not your true RV, live off the grid battery, it is roughly 70aH. I am trying to make the most of my situation.
My question is this: While underway will the inverter drain the battery or find power from, supplemented by, the vehicle's charging system? or am I overlooking something?
