luberhill's avatar
luberhill
Is my barn door tall enough for a class a
Ok my pole barn is 28 x 40 ft with 16 ft walls.. my one overhead door is 12 ft wide by 14 ft tall... now the door probably hangs down about 3” from the header so the opening is probably 13’6”
I can probably adjust it to open to the full 14ft
We may get a class C it an A.. probably 29 FYI long or less... what’s the height needed with the ac unit etc
  • If it's too close and you are concerned....Drop the air and back in. Lower the ride height and be happy.
  • Usually seems the satilite dome is the highest point if equipped with one.
  • With the AC units, I'm right at 13'1". You shouldn't have a problem putting away any size coach....Dennis
  • Tom/Barb wrote:
    A lot depends upon the approach to the door. Flat and level, no problem.
    up Hill ? the rear of your coach may be to high. Same thing in reverse if the approach is down hill.
    No street legal vehicle can be over 13'6" tall.
    Bingo: A hill on the approach can make a big difference.
  • A lot depends upon the approach to the door. Flat and level, no problem.
  • Semis with avan trailer are amax of 13,6.You won't have any problem. My shop has 14 ft. Doors and none of my u it's have been even close.
    Moisheh
  • ours is 12'6. I'd be looking for one that is LESS than 13'6.
  • You will have no problem with most class A's I've never seen one over 13'6"
