Desert Captain wrote:
Snowman9000 wrote:
The Nexus exterior construction is about the same as the big brands. Filon walls and a fiberglass mini-cap on the front end. I would expect them to leak at the same rate as similar units. Now if you look at Phoenix Cruiser, you are looking at a huge upgrade in leak prevention. All IMO.
Sorry Snowman but I could not disagree more. Nexus is easily one of the best built C's out there. Nexus frames in steel (72% stronger than conventional aluminum framing). They use Azdel instead of Luan or plywood (stronger, lighter, higher R value and will NOT absorb moisture). The roof is one piece fiberglass with one piece fiberglass front and rear end caps. You won't find any plywood or particle board anywhere in a Nexus. Hardly the same construction quality as the so called "Big brands", not even close.
I am also very happy with the heated tanks, remote control heated mirrors, electric awning, innerspring mattress, 7' of interior head room throughout the coach and power drivers seat (to name just a few of the high end features found in our Nexus). You can spend a lot more than the price of a Nexus but bang for the buck you will be hard pressed to find a better value.
After nearly 18 months and more than 22,000 trouble free miles we are happier with our Phantom 23P then ever.
:B
Steve, the way I was analyzing it was not about the materials but the way they are fastened together and sealed. I might be wrong, but from looking at photos the Nexus is put together the same way as other conventional C's. Is that not correct?
Leaks occur at seams and fasteners in my experience. I would agree that it is good to have materials which can better survive leaks. We had leaky Jayco trailer, and the floor being plywood instead of OSB saved me a lot of grief. Likewise, Azdel should prevent or reduce delam issues.
To me, the top end of leak resistance is:
Coach House, Born Free, maybe Lazy Daze,
Phoenix Cruiser a little behind them, then
Anything using a full roof to bottom front end cap (typically found on B+ models), then
Any partial fiberglass front end cap, then
Filon front cap at the bottom of the list.
Me personally, I don't feel that roof material matters much in leak resistance, unless/until you start scraping the roof under tree branches. What matters more is how the roof edge seams are designed and installed. My Trail Lite had a TPO roof that was probably a more leak resistant design than the fiberglass one on my Sunseeker.
