einy's avatar
einy
Is This Water Damage
Good morning. We are considering a purchase of a 2006 Winnebago Adventurer 33v that is 500 miles away and the salesman just sent us this pic. Does this look like water damage? Or something else?
  • What kind of ceiling material is that? Without showing any obvious staining is difficult to know for sure.
  • We were told that it is near the center of the coach between the microwave and the dinette.
  • It's difficult for me to tell exactly where that is in the coach.
  • Yes, water intrusion. The Vinyl shows the outward damage. If you gently pulled the vinyl from the center strip you would see rotted wood decking the vinyl glues to. The vinyl will NOT be able to be reglued to the wood. The wood ceiling panel and other damaged ceiling wood decking will need replaced and new vinyl glued to the new decking. Per panel(4 foot by 8 foot) cost at $150 labor rate would be about 4 hours plus materials (about $150 per panel for a total of about $800 per 4 by 8 foot. That is standard warranty time, and not actual Customer pay labor which may increase the hours to 5 instead of 4. AND, you would need to verify the CAUSE has been fixed. Nothing worse than fixing a ceiling problem and the cause has not been stopped. Doug
  • Yes. Unless the asking price is heavily discounted thank the salesman for his time.
  • downtheroad wrote:
    Welcome to the Forum....
    Seeing that, I would save the 500 mile trip.
    Good luck with your search.
    X2... save the trip.
  • Welcome to the Forum....
