whit
Sep 16, 2016Explorer
Issue with window
Hi all,
I have a 2005 National Dolphin. The problem is with one of the small side windows in the slide out. On the window that slides up and down there is a metal rail across the top of the glass. That is what you push up and down, and also the lock is mounted there.
If you look at the picture, you can see the lock on the rail. The metal rail has a channel on the bottom where the glass fits into.
The problem is it is completely loose and actually coming out on the left side.
It appears there is some kind of tape that holds the glass in that channel.
I was wondering if anyone knew for sure or had any experience with this?
Also, if I need to take the glass out do I need to take the window ring off on the inside of the motorhome to get it out?
Thanks
free image upload
Thanks
free image upload
