Ed_Gee wrote:
usersmanual wrote:
our current Suncruiser (2016 38q) is a 50-amp coach with a 5500-watt genny.
means nothing- your genny is only wired to produce 30 amps
I have a 8K onan diesel and the breaker on the gen set is 30 amps
YOUR Generator is capable of 67 Amps....and that 30A breaker you refer to is a dual pole breaker.
yes correct.its actually a 35amp breaker two pole with single throw reset
the thing was the fellow thought his generator put out the same 50amp dual pole system as his SP and it does not as mine does not either.
where he said his coach is 50 amps and so is his gen set. Agreed "" but"" like wolf said 50amp shore power is actually 100amps and 50 amp gen set is well 50 amps
