spinners1
May 13, 2014Explorer
Itasca Sunova TV antenna Coax problem
I have a 2004 Itasca Sunova. Recently we lost reception of TV on the roof top antenna. I have completely diagnosed the problem (I have aback ground in electronics) and isolated it to the coax cable between the antenna and the amplifier inside the coach. It appears to have a break somewhere in it's length. If I jump this with a coax everything works fine. The problem is, how to replace the installed coax. I have looked at all the wiring diagrams and diagrams of how the coach is put together and cannot find a way to replace it without tearing the ceiling apart. I tried the old standby of attaching a wire to the old one and just pulling it through, both from the inside and the outside, but it won't budge.
Has anyone had to replace this coax (it's only about 7 or 8 feet) and how did you do it?
