stugpanzer wrote:
Do you use jack pads? Homemade or purchased? Can you recommended either those that you like or even plans to make some? I have a set of THESE from my Travel Trailer days and when I do use then I place them upside down so I can get them off the ground but would like something more robust for the weight of a Class A Coach.
Thanks!
DW just got me a set of those a month ago & the instructions said the are to be placed flat side down for better strength & weight distro. I used them for the first time on grass the last time we went out along with my home made 4" thick 10"x10". The worked great & kept the big blocks from sinking as far. Been to this same spot the last 5 years. :B
