DrewE
Nov 15, 2020Explorer III
Break the lug nuts loose before jacking. It's usually easier as well to do the final tightening once the jack is removed. Securely chock the diagonally opposite wheel.
For a rear tire, jacking the axle under the spring mount is always safe as that part is always carrying the weight. For the front it depends a bit more on the specific chassis, but it's usually not too tricky to figure out. One jack should suffice just fine.
Hopefully it goes without saying, but do not put any of your body parts under the vehicle while it's supported by the jack. If the jack should slip, they could get crushed, and that's not good for your health and well-being.
38,780 PostsLatest Activity: Mar 30, 2014
