plattpd60's avatar
plattpd60
Jensen 212T Radio Problem
My Radio will not come on. It does not even show the time. It seems to have occurred after I used the (Storage/Use) toggle, switch because the Radio worked before that. It doesn't seem to have power, but all the lights in the camper work after putting the switch back to the use position. I tried toggling it back and forth a few times but it didn't help. Not sure if the Radio has a separate fuse or not. Anyone have suggestions?
  • There should be (2) fuses in-line. One keyed hot for power, one always hot for memory; time, pre-sets, etc. Make sure than one is good.
    I took the Jensen out of ours, I'll check the model number. I may have a replacement if you need it.
  • What year is it? The Jensen radios are junk. Years ago on another MH it had a Jensen radio/camera. I had similar issues as yours, it would come back and then go dead - always at the worst time. I replaced with it with a good name brand. I think either Sony or Pioneer. The Camera/radios are pretty plug and play.
  • I did pull Radio out and it does have power to Radio. When I plugged the connector back into radio I now only get static on the Radio and I don't get anything showing on the face of the radio. No time indication, and buttons on radio don't change anything. I think Radio may be shot.
  • Get your volt meter out and check to see if power is getting to the radio. Start with the basics, it makes trouble shooting easier.
  • You may have an inline fuse in the wire feeding the radio.
  • I did just find some info on the Radio when I entered the Radio on Google and it went to some Forum posts that referred to my Radio so I have a couple things to Check.
