Goldencrazy's avatar
Goldencrazy
Kelderman again
Well I did it again. Many of you know I wrote extensively about my experience with the Kelderman air ride system on my Winnebago Vista 30T. Well we traded it for a Winnebago 35G and a few short rides told us we missed the air ride. So off to Iowa I went to add the Kelderman air ride to this new motorhome. When I arrived they quickly had a team of at least four techs crawling under the moho checking things out and to my disappointment concluded that the rear could not be outfitted as the water heater was located exactly in the wrong place. They suggested however that I might be just as happy with the front as that is the more extensive modification. Well, the front was installed today and I drove over 250 miles non-stop home. What a pleasure. It was so smooth over some poor roads and I had to work to keep the speed down as bouncing and clanging did not impede my speed. The techs said many people just had the front done and were happy. Add me to the list. Now for the warranty repair of my squeaking passenger side slide and things will be perfect. Quiet and smooth. On smaller lighter motorhomes you may need the rear bags but on this heavier coach getting the front smooth made the difference and just getting the tire pressure right was enough. If I should feel in the future that a softer ride is desired i will swap out the Bilsteins for Koni FSD's. Those Bilsteins are really stiff but a good load helps them do the right thing.
