Ok, I have a 2004 Fleetwood Pace arrow, new to us, Question, there is a kingdome satelite dome on top, no receiver, wires labeled in the overhead compartment, can anybody tell me what i need as a rece...
That dome will not work with Dish Network but should still work for DirecTV. With DirecTV you will not be able to get any of their HD programming but you will get all of the available SD programming. This, of course, assumes the antenna itself still works. If the previous owner was a DirecTV subscriber then the antenna is already properly setup. If they happened to be a Dish subscriber you are going to need to have the antenna re-programmed for DirecTV.
