rgatijnet1
Jan 27, 2015Explorer III
You may have a fuse that has blown which would not allow your 12 volt amplifier to supply power up through the coax to your antenna.
The King antenna used to come with it's own 12 volt power supply that you would use if your 12 volts is NOT available through an existing amplifier.
The King antenna is far superior to my old batwing which was a rattling hunk of aluminum pieces.
38,782 PostsLatest Activity: Sep 02, 2026
