Dale_Traveling
Jan 27, 2015Explorer II
I replace the bat wing with a jack antenna a few years ago. Cracked the amplifier housing and the amp got wet allowing the magic smoke out. No new channels I never saw before but the jack doesn't appear to be as directional sensitive as the bat wing. I'm not having to re-aim the antenna as much after changing channels. Also the jack has an LED on the bottom of the antenna so I can see that the amplifier has power easily. I only got the antenna head piece that working with the crank up bat wing rig which only set me back about $40 or so.
38,782 PostsLatest Activity: Sep 02, 2026
