Gundog's avatar
Gundog
Explorer II
Nov 18, 2018
Kitchen faucet MH not working.
Our new to us MH kitchen faucet works part of the time but doesn't much of the time. I removed the faucet it is a single handle with a sprayer. When I say it doesn't work I mean nothing comes out of it no matter the position of the handle. I tried blowing air through it and sure enough no matter the position of the handle nothing comes out the spout. I took it apart thinking something has it plugged but I found nothing. I can blow air through each of the individual parts but when it is re-assembled nothing gets through. It is clean inside and I have taken apart the cartridge nothing is in it. It doesn't leak it just doesn't work.
I have got it to work a few times on the 3 trips we have taken. I have a theory and I think it has something to do with the sprayer that I doubt is factory in fact I don't think this faucet is the original faucet and I believe it is a cheap Glacier Bay sold at HD. The reason I don't think it is factory is there is a soap dispenser in one of the drawers that I believe was once in the hole the sprayer now occupies. I think that when there is air in the lines the 12 volt pump doesn't have enough pressure to unseat the sprayer plunger or something along those lines.
My wife likes the sprayer hose so I need to get something to replace this that works and has a sprayer.
    You should be able to reach the underside of the faucet and disconnect the hot and cold water lines (shut off the water first). You can then turn on the water (hopefully, one at a time) to see if you have good water flow. If you do then go to Home Depot / Lowes and get a new one. If you don't then you are going to have to work your way back to find a crimp or a clog.
  • Is your kitchen on the slide-out? If so, it has flexible hose from the faucet to the water connection. Possibly crimped?
  • Get something to replace it that works and has a sprayer. A new one, not a 'new to us' one.
  • Have a cheap faucet in my garage sink that has a sprayer. The sprayer does not work. I really dont care, so it is there. Go to your favorite big box store and buy a decent faucet and install it.
  • Does it work when hooked up to city water and not running off the onboard tank and pump?
