Teeshot1939's avatar
Teeshot1939
Kitchen faucet woes
I have very little water pressure (both hot and cold) in the kitchen sink faucet of a 2010 Tiffin Phaeton I am intending to purchase. The sprayer attachment has good water pressure and so do to the vanity sinks in the bathroom and hallway. This occurs both on city water and while using the pump and fresh water tank. Got the be the faucet itself right? Am I missing something? Thanks.
  • Teeshot1939 wrote:
    I have a faucet and a separate sprayer...not a pull out sprayer model. I have cleaned the aerator without any improvement. Any other suggestions?
    If you are getting good water pressure in other places then you have a clog someplace. If it isn't the aerator then start at the top and work your way back. Unhook the water lines from the faucet and get a bucket and turn on the pump and see if the flow is good from the line. If it is, then go buy a new faucet, or take the current one apart and clean it out. If it's not the faucet you're going to have to follow water lines. Maybe you have a kink in a line someplace. But you said it's both hot and cold has low pressure, so since they have different water lines, that tells me it's your faucet.
    Do you have one of the new EPA restricted faucets?
  • picture of the fixture please
    without tHe airleator on is it any better flow?
  • I have a faucet and a separate sprayer...not a pull out sprayer model. I have cleaned the aerator without any improvement. Any other suggestions?
    Interesting as I have a 2008 Allegro Bus and my Kitchen faucet does the same thing.Took the filter out of the sprayer and made slight difference;; let me know if a new faucet fixes and I will do the same
  • The inline filter is clogged ? ours does not filter the sprayer, just the faucet.
