- pnicholsExplorer II
midnightsadie wrote:
put one in my V10 rv and it clogged up the mass air flow sensor.
EXACTLY what happened when I put one (temporarily) on my V10 E450 Class C motorhome. The V10 started missing immediately after I installed it and it didn't stop until I replaced the K&N with a good old paper filter like Ford recommends ... and it's never done it since using paper filters.
.... and I do know all about using expensive K&N oil treated filters - have had one on my 4X4 GMC pickup for at least 15 years. I clean it and re-oil it regularly with K&N's red-colored K&N oil.
Maybe the computer controlled V10 engine is a bit like a high spirited but finicky stallion horse - feed it and care for it just right so you can be wowed by it's performance. ;) - Ray___JuneExplorerMany of our area SCCA racers (me included) used them for years without problems, and we held more track records for our area than almost anyone else. I also used it on my '75 Dodge class 'C' which had over 125000 miles on it when I sold it. Follow the instructions, DON'T over-oil and they work beautifully.
- Home_SkilletExplorer III love them!!
Helped payed for my rv and dirt bikes.
Lots of dusted diesel engines. - Desert_CaptainExplorer III
desert captain, you been out in the sun to long. IF you follow k&n,s directions you,ll clog up you mass air flow in about 1k miles.
Your post is rude, ignorant and simply false {you must be so proud}. :S
Tens of millions K&N customers have had no problem following their instructions (these are the folks who actually read and follow them), for decades with excellent results. Not sure why you hate K&N so much but then I really don't care. I have been using K&N filters since 1998 with excellent performance, saving hundreds of dollars over the cheap (often Chinese), paper filters.
:R - timmacExplorerI have the Banks ram air intake, its designed to allow more flow and not allowing the mass air sensor to get oil on it, a K&N by itself does nothing, you need a whole new air intake system to get the benefit.
Note the Banks uses a filter same as K&N but there intake has the filter housing sitting lower than mass air sensor.
http://assets.bankspower.com/prod_images/1027/ford_ramair_0607_68L.jpg - n7bsnExplorer
That is why they are NOT recommended.
Well, that and they allow larger dust particles into the cylinder.
Which you could expect to be hard on your engine. - TachdriverExplorer
I followed the directions to a "tee". Never had problems since 2007. - midnightsadieExplorer IIdesert captain, you been out in the sun to long. IF you follow k&n,s directions you,ll clog up you mass air flow in about 1k miles.
- old_guyExplorerwe raced cars for years and used them on our race cars. one thing to know about K&N filters is if you have a race car you tear down the engine several times a year. the MH or family car not so much. you will suck in more dirt with K&N filters than paper ones. I would not use them in my family car unless it were a rental car and or trade in the family car every year.
- mikeleblanc413ExplorerThat's good to know about the V-10. That is the engine I now have in my Winnie. Used K&N on a Dodge Dually...not good, not bad, expensive. Use WIX now and am pleased.
38,756 PostsLatest Activity: Oct 31, 2025
