Executive wrote:
Reading the title made me think of NASCAR of generators....:B.
The fact it operated ok after spraying it with WD40 makes me think you've got some gunk etc. where it shouldn't be. Cleaning it thoroughly will most likely get you back up and running correctly. Won't cost you much to do and if you have to take it in, the mechanic will appreciate it....Dennis
Unfortunately my spraying turned out to be a red herring. I sprayed it overnight with PB blaster and the Gen set still races. I am wondering if the fuel pump is not getting enough gas to the carb and the governor is overcompensating for it?
