Sanediego's avatar
Sanediego
Kwickie RV step
I had to replace the Kwickie step on my RV ( 2001 Fleetwood Pace Arrow) My new step has a four way plug and my RV has a a two way plug. This is not including the ground wire and light. Do you know how I can convert that without a total cut and rewire?
Thanks in advance, Tom in San Diego
P.S. I tried for an hour to find a phone number for Kwickie before posting this.
  • I have never seen a 2 wire Kwikee step. They all have 4 wires. Unless Fleetwood had a special step built by Kwikee for them.
    1. RED large wire is the POWER (12 volts)
    2. The WHITE wire comes from the On/Off switch
    3. The YELLOW wire comes from the Ignition side of the key switch
    4. The BROWN wire comes from the Pin/magnetic switch in the door frame
    5. The Large GREEN wire that is not to the 4 wire goes to the Chassis ground.
    So, you should have the 4 wire pigtail that has the short wire ends that connects to the 4 wire harness to the step module. That means you do not have to cut any wires.
    Now, there was one model Kwikee step built for Van models that had just 2 wires, BUT, that step had a 6 pin rocker switch that you had to manually extend and close the step. It was NOT automatic when you opened and closed the door. IF that is the step you had, you will have to run the wiring per the instructions and then install the 4 wire system. Yes, cutting the wires would negate the warranty because the do not make the same motor for the 4 wire steps. I do not think they make your type step system anymore. Doug
  • That very straightforward hook up requires cutting all the wires figuring out where they go by colored code and rewiring it and negating the warranty. THE PLUGS DON'T MATCH. But thanks for trying.
  • look at page 9, very straight forward hook up. Has a build in safety that will not let you drive off with the step still out.
    https://www.lci1.com/assets/content/support/manuals/pg-1422279-888-Rev-OI.pdf
