The outside door step sometimes doesn't work.... sometimes gets stuck open and sometimes closed. Anything I should check .... looks like several places sell a fix it kit for around $200. any though...
The older steps used a different switch in the door jam. I believe the old one was normally closed and the new ones use a normally open. It maybe the other way around. Did they send you a new magnetic door switch? Door Switch
