LVJ58 wrote:
Up underneath your step assembly frame toward the back, there should be a bolt on both sides of the frame that retain an eccentric type cam. You can loosen the bolt and rotate the cam to a position where the downward movement of the steps can be minimized. Best when adjusting to have someone to put pressure on the steps while you make the adjustment. Anyway, that's the way it works on our Kwikee steps.
Good luck and let us know how you make out...
Hey LV,
Been a while since we spoke. Your instructions on the adjustment of the "cam stops" for the Kwikee two step models is slightly off some. Before I answered this, I went to my PDF file on my two step Kwikee and checked the adjustment procedure. In that step by step (no pun intended) procedure, that cam is used in conjunction with the motor/gear arm travel.
They don't say anything about having pressure on the step, as the adjustment is made. They simply state, loosen the cams so they turn freely, then, extend the steps, all the way out and, that the rotating arm is against the gear housing.
At that point, you rotate the cams, to the point they're up against the step arms. Then, tighten them securely.
Then, retract the step and extend it, several times, to make sure the adjustment remains correct. The cam(s) are there to make sure there is no play at the last point of extension. But, they are not there for support of the steps, when being stepped on. That is all taken care of by whatever type/style of mounting the entire assembly is attached to. If one has a real strong steel structure that the step is mounted to, it will be considerably more stable, than one that attached to mere body components, like mine. I love our Itasca diesel unit but, that step mounting is for the birds.
I would have copied and pasted the adjustment procedures but, PDFs don't let you do that. At least on my computer they don't. Hope this helps some.
Scott
