Hi All, I was backing into my weekend CG spot when the door was opened as I was sitting with the brake on and the transmission was in reverse. The steps made an awful noise, and now the steps are in ...
Jeff, our coach is on the Ford chassis and has an Intellitec Battery Control center located on the front left of the firewall. The fuse for our kwiKee steps is on the fuse panel inside the control center box it's a 25 amp.
Not sure if your setup is the same, but when you find the fuse panel/block, check for a blown 25amp fuse.
