Hi All, I was backing into my weekend CG spot when the door was opened as I was sitting with the brake on and the transmission was in reverse. The steps made an awful noise, and now the steps are in ...
If you have to there is a pin, that you can remove to allow the steps to move. If you can't find problem, you will need to tie steps up to frame to retract to get home, we have used blocks to keep extended steps in place until I could repair.
