Hi All, I was backing into my weekend CG spot when the door was opened as I was sitting with the brake on and the transmission was in reverse. The steps made an awful noise, and now the steps are in ...
On my 96 Chevy chassis the fuse is a 15 amp and is in the main fuse box on the firewall on the drivers side. More importantly is what caused the fuse to blow. This drove me crazy for a while until I finally found the wire from the ign to the steps was stuck between the slide and the frame and was grounding out causing the fuse to blow. If I remember correctly it was a blue wire.
