schlep1967
Mar 25, 2015Nomad
I'm hoping you did your homework on the choice of laminate flooring in an RV. It seems to me the extreme temps and humidity variations will cause shrinking and expansion issues.
That said, I have installed several laminate floors in homes and I can only recommend one brand. ALLOC Brand. And I would say their "original" model would be what I would go with if I was to put it in an RV. I have seen too many cheaper lock together floors separate due to cold dry winters and dry heat sources in houses. I can only imagine how it will go with an RV parked for the winter with no heat in the northeast.
Good luck with your project!
38,769 PostsLatest Activity: Apr 03, 2026
