Bright_Horizons's avatar
Sep 11, 2018
Large slide issues
Has anyone had any issues with large sides that hold res refrigerators and washer dryers micro wave ovens and Large tvs and awnings all on the same slide ? ie; Challenger 37FH
  • I have found that ensuring that the Jack's are down and the RV is level before extending the slide will go a long way in making sure you never have issues with a full wall slide.
  • Personally based on my experiences I would not have a w/d in a slide out. The movement I experienced when spinning on the main floor was enough to cause concern some times. Especially when it got uneven.
  • You probably won't have an issue, but I'd be trying to reduce the shaking by balancing the load. Front loader machines don't seem to have this problem.
  • No problems yet but we will be adding the washer and dryer that will increase weight by up to 600 lbs plus all the shaking on the spin cycles when the slide is out. are there any telltale signs of slide failure that we should look for?
